Inserting mother grids
Tool |
Tool set |
Mother Grid
Rigging/Braceworks |
When a venue’s rigging points are insufficient, a mother grid can be added. Mother grids can support the horizontal forces applied by bridles. Each mother grid consists of one truss and three hoists. The Mother Grid tool inserts a mother grid on house rigging points or structural members (see Creating structural members).
Mode |
Description |
Auto Insertion
Inserts a mother grid using Auto Connect technology to highlight valid attachment points |
Click Insertion
Inserts a mother grid with three clicks to identify the start point, end point, and connection point of the truss system |
Symbol |
Opens a Resource Selector to select the truss symbol for the mother grid; double-click a resource to active it |
Trim Height |
When Click Insertion is selected in Top/Plan view, enter the hoist hook height. Whether this height applies to the high or low hook depends on how the mother grid is inserted. If you insert the mother grid on house rigging points, this value sets the low hook height. If you insert a mother grid above an existing truss, this value sets the high hook height. |
Preferences
Opens the Select Hoist dialog box, to select the hoist symbol to use in the mother grid |
